JD 4840 hydraulic light
/ JD 4840 hydraulic light #1
ojackson
Quincy,florida
JD 4840
Hydraulic light comes on when clutch pedal is pressed on my JD 4840. What would cause this?
/ JD 4840 hydraulic light #2
:welcome: to TBN
How long since hyd filters were changed and sump screen checked/cleaned??
Filters changed and sump cleaned recently. Can start tractor and let run, light does not come on until clutch is pressed.
/ JD 4840 hydraulic light #4
I'd suggest to check pressure with a gauge(155-165 psi) Which trans(QR or PS)?
/ JD 4840 hydraulic light #6
What is the history of the problem? Does transmission operate normally in all gears? Have any parts been recently replaced? Does light come on in all gears when clutch is depressed?
/ JD 4840 hydraulic light #7
had this problem and it was simply the clutch linkage touching a bare spot in wire going to sender
Tractor shifts thru all gears, although 1st is sometimes sluggish. No parts recently replaced. Light started coming on this past season. I just noticed that light does not illuminate until clutch is depressed. will check for wire shortage.
Checked pressure at clutch valve and it was 160 psi and dropped to zero when clutch was pressed. I still can force light to come on by pressing clutch pedal, I can force light to cut off by engaging PTO on and back off.
2019 JOHN DEERE XUV855M S4 CART (A66091)
2019 JOHN DEERE...
JOHN DEERE 1705 - 6R36" VACUUM PLANTER (A64278)
JOHN DEERE 1705 -...
1200 GALLON FLAT BOTTOM POLY TANK (A64278)
1200 GALLON FLAT...
2016 CATERPILLAR D6K2 LGP CRAWLER DOZER (A65053)
2016 CATERPILLAR...
2007 Ford F-150 Ext. Cab Pickup Truck (A64556)
2007 Ford F-150...
LOT OF SCRAP IRON AROUND CEDAR TREE (A63291)
LOT OF SCRAP IRON...
