JD 48 Backhoe slowly leaking fluid out of top port on valve
   / JD 48 Backhoe slowly leaking fluid out of top port on valve #1
Robertpower3
Richmond, TX
John Deere 5105 4WD WITH 48 HOE and 522 FEL
New to the site and hydraulics in general so thanks in advance for your patience. I have a John Deere 5105 with a 522 front end loader and a JD 48 backhoe. My backhoe is leaking hydraulic fluid slowly from one of the top ports on the valve section and I'm having difficulty figuring out which parts I need to inspect based on the diagram so I pulled off of John Deere's website. I believe the leak is related to pressure relief valve on the boom-dipper stick valve. I'm attaching pics to hopefully help with the ID. Thanks
   / JD 48 Backhoe slowly leaking fluid out of top port on valve #3
You can try tightening all connectors. Then degrease and clean everything well. When it's dry dust on a bit of talcum powder. That will help pin down the actual leak location.
   / JD 48 Backhoe slowly leaking fluid out of top port on valve #4
Looks like a work port relief cover, should be just a male boss oring. If it’s coming from between sections you’ll be looking at a tear down and reseal complete valve.
EASTWOOD MIG250 WELDER (A51248)
EASTWOOD MIG250...
2003 Volvo S60 Sedan (A53117)
2003 Volvo S60...
2023 John Deere Z994R (A50123)
2023 John Deere...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2020 Ford F-250 Pickup Truck (A51692)
2020 Ford F-250...
