JD 48 Backhoe slowly leaking fluid out of top port on valve
   / JD 48 Backhoe slowly leaking fluid out of top port on valve #1
Robertpower3
Richmond, TX
John Deere 5105 4WD WITH 48 HOE and 522 FEL
New to the site and hydraulics in general so thanks in advance for your patience. I have a John Deere 5105 with a 522 front end loader and a JD 48 backhoe. My backhoe is leaking hydraulic fluid slowly from one of the top ports on the valve section and I'm having difficulty figuring out which parts I need to inspect based on the diagram so I pulled off of John Deere's website. I believe the leak is related to pressure relief valve on the boom-dipper stick valve. I'm attaching pics to hopefully help with the ID. Thanks
   / JD 48 Backhoe slowly leaking fluid out of top port on valve #3
You can try tightening all connectors. Then degrease and clean everything well. When it's dry dust on a bit of talcum powder. That will help pin down the actual leak location.
   / JD 48 Backhoe slowly leaking fluid out of top port on valve #4
Looks like a work port relief cover, should be just a male boss oring. If it’s coming from between sections you’ll be looking at a tear down and reseal complete valve.
UNUSED LANDHERO MIG-140 WELDING MACHINE (A51248)
UNUSED LANDHERO...
Tailift 5000 Forklift (A53117)
Tailift 5000...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2021 CATERPILLAR 420XE BACKHOE (A51246)
2021 CATERPILLAR...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
JOHN DEERE 17P LOT IDENTIFIER 108 (A53084)
JOHN DEERE 17P LOT...
