jd 4600
/ jd 4600 #21
<<<I think it's a "don't ask, don't tell" thing.>>>
I think it's a "dont ask (a dealer/salesman who doesn't know, because he), CAN'T tell (reliably) thing"!
/w3tcompact/icons/smile.gif Larry
/ jd 4600 #22
Larry,
.... Just don't hit me in the head with your loader!
I didn't mean to start a loader war... honestly.
Maybe you can call JD corporate and ask them why they think it's a misprint as I was told, and then they show the "1705" ratings in other literature they print. Remember, I didn't print it... they did.
Larry, maybe we should have started a thread just on the 460 vs 521 loader... (Just kidding Larry)
I started out just explaining some differences in the 4700 and 5105... and you're wacking me with your loader bucket... Help!
John III
/ jd 4600 #23
JohnIII,
Quitchercryin! Darn it, I'm tryin' to "whack" gently./w3tcompact/icons/wink.gif
As I said, I think the confusion (at every level, corporate/sales/whatever... they're all just people) arises from the two specs. being given in various pamphlets, etc. One time the "pivot-pin" spec... another the "V" spec., but they're both called simply "max lift", with only one shown, and no mention of the "pivot-pin"/"V" distinction. That gives the reader an impression that the "max lift" is 2325 or 1705 lbs., depending on which pamphlet he is looking at.
I don't imagine whoever is putting together the sales literature gave up a job in rocket science to do it. So I'm putting my confidence in the tech-manual writer who knows that bum dope can result in broken equipment/injured operators...both of which translate into liability lawsuits. Bottom line...it could cost the company MONEY,(and his bosses won't like that).
I appreciate your posts. I added mine in the interest of accuracy... not a war!
/ jd 4600 #24
Larry,
Thanks for posting the manual info from the 460 book.
FEL specs was the most confusing thing for me to devine when trying to buy a tractor because of all the different specs that were given. I A S S U M E D that JD would measure the performance the same way across the FEL models. Comparing different brands was the hard part so I gave the FEL performance a little lower wieght to compensate for the spec issue.
Again I A S S U M E D that the "dumbing" down of the 521 on the 5n05 tractor was due to some hydraulic magic of some kind on the tractor. I can't imagine that the 521 FEL is any different on the 5n05's or the 5n10s. So there must be something on the 5n05's the prevents the full capacity from being used. I really wish that I had asked the sales people about this....
But it would not have changed my purchase because of the backhoe. The 7,000 for the JD 48 back hoe was a budget buster, going another 3,000 for the 5n05s back hoe would have been impossible. But I some times still dream of the 5000s.... :cool:
I guess we need someone with a 521 to tell us what is in their manual! Then we need someone with a 521 and a 5n05 to start lifting known wieghts and I'll do the same! Instead of the Nebraska Tractor Reports we will have the TBN Tractor Reports! :cool:
Later...
Dan McCarty
/ jd 4600 #25
Roy,
I was told buy the SalesDude that the JD insurance covered everything on the tractor if something was stolen or vandalized which is my main worry. I asked if I drove it off a cliff did the insurance cover the tractor? He said yes. I'm not sure I believe that but I'm not planning on driving off a cliff. I really don't have any cliffs on the property but I do have som real nasty drop offs that would do a job on the tractor. I don't want to think what the tractor and the dropoff would do to me!
I really need to go read the JD policy to see the real coverage. On the other hand I'm not that concerned since my real worry is the stolen/vandalism issue. Our original financing plan was to get a home equity loan since it really lowered he payments but we did not want to have a problem building a house because of the tractor being tied to the house.
The loan officer has since told me that a home equity loan will not hurt the construction to perm loan. Since our house building project may be put off for a year or more I'm might go ahead an get the equity loan to improve cash flow. At that point I would have to get my homeowners policy to cover the tractor. JD's policy only covers the tractor when under a JD loan according to the SalesDude.
Usually I read policy's real carefully, as I did our homeowners regarding the tractor, but I did not read JDs. Kinda scares me.... 8-(
Hope this helps...
Dan McCarty
/ jd 4600
John thanks for the info, I think Iam still alittle confused on the loader capacities.. Doesnt make since to me..
Well I was considering buying now if the 4600 would of been for me, but since I dont feel totally comfortable with the hydro I will wait even though its almost 5000 saving on the way its rigged.. I have utility size deeres now but I want to upgrade to power steering etc. I also have a 580 bachoe but when i do small jobs that require a loader the 580 seems a bit over kill. We are in the planning stages of building a mobile home park, hoping to start by May. So this is the other reasoning behind getting another loader.. I plan on digging a pond and moving the dirt with the (new) loader.. I need the dirt to build pads ETC.. Anyway I will make a move by March. Iam also finishing out a house right now so the timing and the weather here dont include lots of tractor work.. I do have a couple of grinding jobs but in place where a tractor would do to much damage right now..
/ jd 4600 #27
Dan,
You're more-than-welcome.
I didn't add, but maybe it won't hurt, that the 2325/1705 figures represent the SAME ability of the loader. It's just that the LOAD has a longer lever with which to resist the loader, when the load is applied at the front edge of the bucket.
That is also why the "pallet-fork" rating is even less (1320 lbs, I think)... the CG of a loaded pallet is even further foward of the pivot-pin, therefore even better-able to "resist" the loader's force. (If the forks were long enough, a chicken could light on the end and tip your tractor over/w3tcompact/icons/shocked.gif!)
These "less-capacity further-from-the-pivot" specifications are simply the result of physics, and would apply equally to ALL loaders!!
The only way to realistically compare loader capability is to be sure you are comparing "apples-to-apples". The pivot-pin spec. (JD460 = 2325 lbs.) is the one commonly given on "spec-sheets"...just check to be sure that IS what is being stated.
The more we discuss/investigate... the more we all learn. What a great list!
/ jd 4600 #28
Dan,
Another thought: If you can find a dealer with the 5N05/5N10 tractor and/or 521 loader at his site, he probably has the manuals that come with them also.
If he's a "good-guy", he may let you look at them, and you can see what they say about the performance figures. If you explain what the questions are, he may be curious-enough to want to look for his own information, as well.
Can't hurt to ask... /w3tcompact/icons/wink.gif!
Larry
/ jd 4600 #29
Larry,
If I can get a scanner hooked up, I will scan my 521 spec page and post it. However, they don't show all the nitty gritty spec's as the 460 page does.
/ jd 4600 #30
Ok Guys, I've got the 521 spec's scanned, how do I send as an attachment or paste as a "photo" ?
/ jd 4600 #32
John,
You have to first register to attach files... you can register at http://www.tractorbynet.com/cgi-bin/compact/newuser.pl ... it is FREE, easy, safe, secure, and private... many great features if you register, in addition to attachments. /w3tcompact/icons/wink.gif
250 gal Livestock Lick Tank (A66408)
250 gal Livestock...
2021 CATERPILLAR 299D3 XE SKID STEER (A65053)
2021 CATERPILLAR...
2011 Ford F150 Pickup Truck (A64194)
2011 Ford F150...
2016 KUBOTA SVL90-2 SKID STEER (A65053)
2016 KUBOTA...
2018 International WorkStar 7300 2,000 Gallon Water Truck (A64556)
2018 International...
Case IH 181 Rotary Hoe (A66408)
Case IH 181 Rotary...
