JD 4600 Yanmar 4TNE84 engine rebuild problem - Crankshaft balancer
   / JD 4600 Yanmar 4TNE84 engine rebuild problem - Crankshaft balancer
Probably a safety switch.
Do you still have your seat presence safety? That one kills the engine. The others keep you from starting, IIRC.
As for the interesting problem with the balance shafts, I suspect not only the crankshaft does not swap with the non-shaft version, possibly the pistons don't either. I have rebuilt 4 of the 3-cyl versions of this engine (3TNE84), and the pistons have steel weights cast into their undersides. No balance shafts.
I found the problem in the seat safety switch, thank you for all of your help!!
Dan
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2016 Dodge Charger Sedan (A55758)
2016 Dodge Charger...
FORKLIFT MANLIFT BASKET (A55745)
FORKLIFT MANLIFT...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
