JD 4600 Yanmar 4TNE84 engine rebuild problem - Crankshaft balancer
   / JD 4600 Yanmar 4TNE84 engine rebuild problem - Crankshaft balancer
Probably a safety switch.
Do you still have your seat presence safety? That one kills the engine. The others keep you from starting, IIRC.
As for the interesting problem with the balance shafts, I suspect not only the crankshaft does not swap with the non-shaft version, possibly the pistons don't either. I have rebuilt 4 of the 3-cyl versions of this engine (3TNE84), and the pistons have steel weights cast into their undersides. No balance shafts.
I found the problem in the seat safety switch, thank you for all of your help!!
Dan
2017 HAMM H51P PADFOOT ROLLER (A52706)
2017 HAMM H51P...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A55745)
2013 ORTEQ ENERGY...
ELECTRIC GOLF CART (A55745)
ELECTRIC GOLF CART...
197711 (A51244)
197711 (A51244)
