JD 4600- cuts off when putting into gear or turning on pto
   / JD 4600- cuts off when putting into gear or turning on pto #11
changed fuel filter 6 months ago. its running fine just can't move it.
Sorry I got the impression from the post it was running fine until you put it into gear and released the clutch and then it died.
You do know that the fuel demand increases when you shift into gear and try to move the tractor don't you? If the fuel delivery is not adequate, the engine will die. Am I'm I missing your symptoms?
Doesn't matter when you changed the fuel filter. Blockages can occur at the tank outlet, in the passages of the filter head, a pinched fuel line, etc.
By all means check the electrics to the fuel shut off solenoid but don't neglect other possible causes.
1995 POLAR TANK TRAILER TRANSPORT TRAILER (A55745)
1995 POLAR TANK...
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
402 (A52706)
402 (A52706)
2015 Nissan Versa SE Sedan (A55853)
2015 Nissan Versa...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
