JD 4600- cuts off when putting into gear or turning on pto
   / JD 4600- cuts off when putting into gear or turning on pto #11
changed fuel filter 6 months ago. its running fine just can't move it.
Sorry I got the impression from the post it was running fine until you put it into gear and released the clutch and then it died.
You do know that the fuel demand increases when you shift into gear and try to move the tractor don't you? If the fuel delivery is not adequate, the engine will die. Am I'm I missing your symptoms?
Doesn't matter when you changed the fuel filter. Blockages can occur at the tank outlet, in the passages of the filter head, a pinched fuel line, etc.
By all means check the electrics to the fuel shut off solenoid but don't neglect other possible causes.
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2015 Ram 5500 Versalift SST-40NE 40ft Sign Bucket Truck (A55852)
2015 Ram 5500...
JOHN DEERE LAWN MOWER (A55758)
JOHN DEERE LAWN...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
Tennant 800 Ride-On Street Sweeper (A53421)
Tennant 800...
