JD 455
/ JD 455 #1
bseifert2
Quakertown, PA 18951
JD4310
Engine began knocking and blowing light blue smoke, engine oil level dropped from full to half.
Tractor has 1700 hrs. 21 years old. Any thoughts on possible problem?
/ JD 455 #2
No idea, but :welcome: to TBN
What is your mechanical skill level? up for doing any wrenching on your diesel engine?
/ JD 455 #3
Has the oil and filter being regularly changed with the proper oil and filter ? Was the oil level between add and full ? Was the tractor being operated on a hill?
/ JD 455
Yes followed JD maintenance recommendations. Oil & filter were changed in June of this year. Oil level was at full after changing. After problem started checked oil level and this is when i noticed oil level between add and full. No signs of leaks. I was driving on level area when problem started.
/ JD 455 #7
Those little Yanmar diesel engines should have the valves checked every 1000 hours. Doubt this is problem related, but it never hurts to check them.
/ JD 455
Thanks
I put some fuel cleaner in the tank. Left it set and fired it up today. Runs like it should.
/ JD 455 #9
Good to hear.
What "fuel cleaner" did you use?
White 5100 12R Planter (A66285)
White 5100 12R...
2014 Ford Expedition SUV (A64557)
2014 Ford...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
Swict 78in Bucket Skid Steer Attachment (A64553)
Swict 78in Bucket...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
Panorama Hay Rake (A66408)
Panorama Hay Rake...
