JD 455 pto speed?
Status
Not open for further replies.
/ JD 455 pto speed? #1
Bowhunter
southwest Indiana
Kubota BX2200
My dad has a 455 garden tractor and a 445 rotary tiller (54" pto driven). I have a Kubota BX2200 and am hoping to find a pto adapter that will let me hook up the pto shaft to my tractor. My tractor has a regular male end on the tractor, while the tiller's pto shaft also has a male end.
My question is does anyone know the pto speed of this tiller? I know some cat. 0 equipment runs at 1000 rpm. My tractor runs at 540 rpm. I want to make sure I'm not wasting my time finding an adapter if the speeds don't match. Thanks.
/ JD 455 pto speed? #2
The PTO on the older 400 series tractors was a 540 pto,
but you can see they had the driveshaft setup different, with the tractor having the female end. They did sell a stub shaft,
which would allow a normal shaft to hook up, but in your case it sounds like you are going to need the front PTO shaft on the tiller to hook up to your tractor. Other than that, I think you should be ok, and the tiller should work well for you.
/forums/images/graemlins/cool.gif
/ JD 455 pto speed? #4
The rear PTO speed on the older 400, 420 and 430 model garden tractors was 2000 RPM and on the 425, 445 and 455 it was 540. You are correct about the female portion on the tractor PTO.
He should be able to get a new PTO shaft to match his tractor and be OK on that tiller
/ JD 455 pto speed?
After searching Rural King for a female to female adapter, and the local JD dealer for either an adapter or the tractor end of a pto shaft that would work.....I came up empty. Does anyone know of a place online that sells adapters?
/ JD 455 pto speed? #6
Rudolphs JD in St. Cloud, MN stocks the shaft.
rudolphsinc.com 800-645-5531
/ JD 455 pto speed?
Thanks very much for your help Barry! I'll try calling them today. /forums/images/graemlins/laugh.gif
/ JD 455 pto speed? #8
Boy, this thread looks very familiar
You should try to avoid cross-posting, it causes disjoint conversations.
/ JD 455 pto speed?
It's not something I do on a regular basis, and I was desperate. I wanted to make sure I hit all the places where people might know something. There are only certain places on this board that I visit on a regular basis, and I'd guess that others do the same.
If you took the time to read through my threads, you'll see that there was no disjointed conversations. Sorry if I caused you undue stress by doing what I did. /forums/images/graemlins/crazy.gif
/ JD 455 pto speed? #10
Duplicate of this thread.
Forum Rule 2. Do not cross-post your message to multiple forums.
Thread closed.
Status
HARDEE TRAILER (A63291)
HARDEE TRAILER...
3PT HYD SCRAPE BLADE (A63291)
3PT HYD SCRAPE...
2010 Dodge Grand Caravan Van (A61574)
2010 Dodge Grand...
TRAILSTAR 38' FRAMELESS DUMP TRAILER (A63291)
TRAILSTAR 38'...
2007 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A61573)
2007 Dodge Ram...
1987 GMC 6500 FLATBED TRUCK (A63291)
1987 GMC 6500...
