Oil & Fuel JD 450G Dozer: Transmission Fluid Level
   / JD 450G Dozer: Transmission Fluid Level #1
bcavender
Murfreesboro TN
Kubota
Just picked up an older 450G crawler (direct drive) for the farm and the previous owner forgot to bring the Operator's Manual. I am new to this machine.
While waiting on it to show up in the mail, I started going over the detail to make sure it is in shape to go to work.
My question:
Is the transmission fluid level check done with the unit level and engine off or does it need to be idling and warmed up?
Thanks!
Best regards,
Bruce
Exurban Tennessee
   / JD 450G Dozer: Transmission Fluid Level #2
Transmission dipstick is key 15
Hi Jim,
Thanks for the reply.
From the looks of the transmission case in the pic you sent, probably just the static level on the dipstick with the engine off is all that is necessary for a valid check?
Do you agree? (Hopefully my op manual will arrive shortly!)
Thanks for the assist!
Bruce
   / JD 450G Dozer: Transmission Fluid Level #4
iirc ON MY 550 THERE IS A HOT AND A COLD MARK BUT I'LL HAVE TO GO CHECK THE MACHINE SOMETIME.
   / JD 450G Dozer: Transmission Fluid Level #5
If it shows between the marks on the stick that should be good enough to try that puppy out.
Got between the marks and the test drive went very well.
Hygard JDM20A is recommended, but that appears to be an obsolete designator.
Anyone know the number of the fluid that took its place?
Thanks!
B
   / JD 450G Dozer: Transmission Fluid Level #7
I would think Hy-Gard hyd oil(JDM-20C) would be the oil recommended for a 450G
2022 Ford Escape S AWD SUV (A54815)
2022 Ford Escape S...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2018 CATERPILLAR 299D2 SKID STEER (A52709)
2018 CATERPILLAR...
2007 Terex Dump Truck (A55973)
2007 Terex Dump...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
