JD 450E tracks
   / JD 450E tracks #1
ch47dpilot
Enterprise Alabama
09 Kubota L3400
The tracks on my 450E dozer are stiff. Only a few can be moved up/down by hand. I think it may just be rusty. Local JD dealer said they've had some luck with driving dozer and pouring old oil/hydraulic fluid on the track as it rolls. Anybody done this or have other tricks.
   / JD 450E tracks #2
We used a hand held pump sprayer with pb blaster (1 gal can) and diesel fuel. on a excavator.
   / JD 450E tracks
Where did you get on blaster by the gallon. Did you mix it with diesel or spray them separately. After spraying did you just let it soak or did you drive right away to get tracks flexing. If soaked first how long.
   / JD 450E tracks #4
Hi I think napa auto parts mixed 1 gal pb 2 gal diesel sprayed moving slow back and forth then again let it soak You have to run it to get the tracks loose ,spray it over nite then run it
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
1998 Jeep Cherokee Sport (A50123)
1998 Jeep Cherokee...
2016 FREIGHTLINER CASCADIA DAYCAB (A53843)
2016 FREIGHTLINER...
2014 INTERNATIONAL PROSTAR SLEEPER (A53426)
2014 INTERNATIONAL...
2020 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2020 Ram 1500...
