JD 4500 turns over but will not start, left alone for 15 minutes and starts?
   / JD 4500 turns over but will not start, left alone for 15 minutes and starts? #1
paradox998
JD 4500
Looking for some help. I have a 2000 JD 4500 with 800 hours. When I try to start it, it turns over well but does not start. After trying several times, I let the tractor sit for a little while and it usually starts. I have checked the ground wire connection on the block and it seems fine. Any idea of the problem or solution. Thanks for the help!
   / JD 4500 turns over but will not start, left alone for 15 minutes and starts? #2
Fuel ? Fuel filter been checked/replaced, and no water in the sediment bowl ? Do you hear the solenoid click and open the fuel shut-off when you turn the key on ? After it sits awhile, and then starts and runs, does it run smoothly or by fits and rough running?
   / JD 4500 turns over but will not start, left alone for 15 minutes and starts? #3
Supply pump.??
Does it do that after using it.. or does it start right up.??
If I has the no-start condition first thing and then it’s fine thru out the day, I would say supply pump.
Thanks, I will recheck the fuel filter. I wondered about the selenoid. I had not thought about the fuel pump but will look into it.
   / JD 4500 turns over but will not start, left alone for 15 minutes and starts? #5
Check and replace the thermister.
Well I replaced the thermister, not the easiest job but I got it done. Turned the key, heard sharp sound and now the tractor is completely dead. It blew the 30 fuse on the starter circuit. I put in a new fuse and nothing when I turn the key. Some days it is better not to fix things! Open to any suggestions at this point!
   / JD 4500 turns over but will not start, left alone for 15 minutes and starts? #7
So much for my advice!
   / JD 4500 turns over but will not start, left alone for 15 minutes and starts? #8
Lol.!!:unsure:
   / JD 4500 turns over but will not start, left alone for 15 minutes and starts? #9
I had the same problem and found that the vent in the fuel cap had some blockage causing a vacumm.
Thanks to everyone. I decided that I needed to figure out the problem based on all the advice. Turns out it was a set of 3 issues. Replacing the thermister really helped on the fuel solenoid. Now I get a strong click everytime I turn the key. Before, I often did not hear a click. Second while the battery tested ok, it was old and when I put a charger on it the meter showed on 50% of rated capacity. I bought a new battery. Third while installing the new battery I found a crack in the cable end that attaches to the positive terminal. Thus, I could not tighten the cable securely to the battery post and the cable was loose although it looked ok. I cut the cable and installed a new end.
Now the tractor is starting every time and runs well. Thanks to everyone for the help.
1264 (A58374)
1264 (A58374)
Doosan D35S-5 6,900lb Diesel Forklift (A55973)
Doosan D35S-5...
2013 Ford F-250 Pickup Truck (A55973)
2013 Ford F-250...
2009 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2009 Ford F-250...
2015 Ford Explorer AWD SUV (A56859)
2015 Ford Explorer...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
