JD 4500 3rd SCV
/ JD 4500 3rd SCV #1
MMH
Murrysville, PA
JD 4500
I have a John Deere 4500 with a 3rd Selective Control Valve (SCV). I just got a grader blade w/ a cylinder & finally will use the 3rd SCV. Is there a standard type hydraulic fitting for the JD SCV? I need to know so that I get the correct hydraulic hoses made up.
/ JD 4500 3rd SCV #2
I believe the QD on the FEL should fit the 3rd SVC. Your local JD dealer should be able to help you out though. Good luck. Roger
/ JD 4500 3rd SCV #3
AM105467 is the male tip, is 1/2 orb threads. Deere did not change full size compacts to the industry std 1/2" iso tip until partway through 20 series production.
2008 KENWORTH T800 DAYCAB POLE TRUCK (A65643)
2008 KENWORTH T800...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
New 2x27 Ratchet Strap (A65579)
New 2x27 Ratchet...
2013 International WorkStar 7400 Crane Truck, VIN # 1HTWGAAR0DJ296617 (A65563)
2013 International...
2011 Ram 2500 Longhorn Laramie 5.7 HEM (A62679)
2011 Ram 2500...
2022 EZ-GO ELITE...
