JD 448 backhoe - anyone add a thumb?
   / JD 448 backhoe - anyone add a thumb? #1
CrashedCT
Woodbury,Connecticut
2007 John Deere 3320
Hey everyone.. I have been looking quite a bit and am in desperate need of a thumb for my JD 3320 with 448 backhoe.. has anyone found a bolt-on one that fits or a weld-on one? any help, pictures, or advice would be greatly appreciated. Thanks in advance.
   / JD 448 backhoe - anyone add a thumb? #2
I put one one my model 48 backhoe, but this was a custom-built hydraulic thing. I think you're looking for something that's more off-the-shelf and a little bit faster than this.
Thank you for the response.. I was looking for a bolt-on solution.. but to gain the versatility a thumb provides I am open to any solution at this point. very helpful. thank you.
   / JD 448 backhoe - anyone add a thumb? #4
So my recommendation would be to start out with a fixed thumb that shares the pivot with the bucket, if at all possible. Then later you can add the hydraulics. Having the hydraulic thumb is such a huge improvement. You can bring it out and just go pick stuff up, then tuck it away when it’s not needed. But, it’s a bit of work to get that all worked out, and I couldn’t find any other alternative and the build it. I had considered the fixed weld on or bolt on ones.
   / JD 448 backhoe - anyone add a thumb? #5
The Thumb I added to my forks was bolt-on, also could for a bucket. Price was reasonable, IMO.
Don't know what your limits or possibilities are with your backhoe bucket.. a pic would help with dimensions. Or let you take it the next step and contact greens-machine.
   / JD 448 backhoe - anyone add a thumb? #6
Beenthere: What the heck? Now I won't be able to sleep until I put one of these on my loader. Fantastic addition!
   / JD 448 backhoe - anyone add a thumb? #7
I am also trying to add a thumb to the 448 backhoe. The thumb itself seems easy to find. There is a Vevor thumb on sale for $205.99, all 1/2" steel with an 18" thumb. My issue is how to add the hydraulics. I am thinking of using the valve off an old Fisher belt drive snow plow. All I need to do is to get the hydraulic flow to the valve. I have used the same valve for other operations. I use one to drive the chute in my old JD 7' snow blower. The fluid pump attaches to the drive shaft via a vee belt running just behind the slip clutch. The hydraulic hoses go from the pump to the fisher valve and from there to a little hydraulic motor that has a chain sprocket on it . Then a bicycle chain runs of that which goes around the base of the chute and turns it. If I can pick up hydraulic fluid near the backhoe valve I would be all set, just need to make up a foot pedal to engage the valve. Any ideas would be appreciated. Thank you.
   / JD 448 backhoe - anyone add a thumb? #8
If you want to have a nicely operating thumb, my recommendation is to put the right valve on, not something that you just laying around. They’re not all that expensive.
   / JD 448 backhoe - anyone add a thumb? #9
I would like to do that and I think that my post was asking for help. I don't know what the "right valve" is. Could you advise me? Thank you
   / JD 448 backhoe - anyone add a thumb? #10
I would be delighted to help you. Earlier in this thread I posted a link to another thread where I detailed everything I went through to develop a thumb for my model 48 backhoe. Everything you need is in that thread. I received a lot of valuable help from people on this forum. Now it’s my turn to return the favor.
Land Honor Quick Attach Articulating Boom Mower (A50514)
Land Honor Quick...
Case IH 1020 Platform (A50514)
Case IH 1020...
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
