JD 445 Tractor Won't Start
/ JD 445 Tractor Won't Start #1
markv5775
JD 445 Tractor Won\'t Start
I'm with a local little league and we have a JD 445 tractor with a 60" mower deck that will not start. The other day, when driving it to the field to mow, it just died. It turns over great, we ahve spark and fuel. Fuel pump works fine but the left cylinder seems to be flooding. We pulled the sparks plugs, put in new but everytime we try and start it the left cylinder does the same, it floods. If we pull the left plug out, disable the fuel pump and blow out all of the gas in the left cylinder and then repalce that plug, we can get the motor to fire but it wont start. When we pull that same left plug, we blow gas out of the cylinder, but the right one is just fine. This seems like a serious failure, any suggestions? The tractor is about 10yrs old and is a fuel injected throttle body 22hp motor.
/ JD 445 Tractor Won't Start #2
Re: JD 445 Tractor Won\'t Start
What you are describing sounds like a stuck valve /forums/images/graemlins/frown.gif Did you do a compression check?
The Johd Deere dealer has suggested that it is a broken cam gear. On some of the older models, this gear was made of plastic. We did pull one of the valve covers off to see if the valves were moving, and they were not.
2011 Ford Crown Victoria Sedan (A59231)
2011 Ford Crown...
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
2000 CATERPILLAR 988F WHEEL LOADER (A62129)
2000 CATERPILLAR...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
2004 Toyota Camry Sedan (A59231)
2004 Toyota Camry...
