JD 445 Sputtering when up to temp
   / JD 445 Sputtering when up to temp #1
PC66
Waukesha, WI
John Deere 445
Greetings, hoping someone out there can help me out. I have a JD 445 with a 22 Kawasaki EFI. First time I've had this issue, once it runs for 20-30 min the engine begins to sputter, it won't die, even with PTO engaged, but gets close. If I shut down the motor, wait 5-10 seconds, it will run fine again for 15-20 minute before the problem returns. So far I've changed the plugs, coils and caps and fuel filter. I've seen other posts that this may be a fuel pressure regulator issue or possibly the MAP sensor, any help is appreciated!
2015 Kia Optima Sedan (A46684)
2015 Kia Optima...
2019 Bobcat T770 Two Speed High-Flow Compact Track Loader Skid Steer (A46683)
2019 Bobcat T770...
TPM 16 Mini Excavator (A49251)
TPM 16 Mini...
2016 Volkswagen Passat S Sedan (A48082)
2016 Volkswagen...
Killbros 350 Gravity Wagon (A49251)
Killbros 350...
New Bush Hog FSP-800 3pt. Fertilizer Spreader (A49339)
New Bush Hog...
