JD 4410 won't start
   / JD 4410 won't start #1
widmn
Nevada
JD870
JD 4410 won\'t start
After intense bushhogging yesterday afternoon, I shut it off and went to bed. Got up in the morn after leaving it outside in a thunderstorm (unusual for me as its usually garaged) and it won't start. Engine turns over if I connect the starter + to the starter -, but only turns over without starting. All the lights go on when I turn the key. Could one of the safety switches under the seat or in the tranny or something be out? Could I have ripped the tranny neutral safety out bushhogging?
   / JD 4410 won't start #2
Re: JD 4410 won\'t start
Is the PTO disengaged? There's a safety switch there too but you probably knew that /forums/images/graemlins/wink.gif
I take it that your are shorting across the starter solenoid to get it to turn over? If so, you can't be in the seat at the same time.
Yes the PTO is disengaged and I am not in the seat but the gears are in neutral. Thanks
   / JD 4410 won't start #4
If you're out of the seat, wouldn't the seat safety switch keep it from starting?
   / JD 4410 won't start #5
I often start mine without being in the seat, only the pto engaged would affect this. There are two solenoids under the right side - it is on the side of the transmission. I am pretty sure one is for the pto. Check those wires.
Of course, you have skid plates. Right?
   / JD 4410 won't start #6
I can definately start my 3320 with the ptos off and me out of the seat. No gears - ehydro (so I guess 1 gear)
   / JD 4410 won't start #7
I'd definitely check your seat / neutral / pto switches. One may have gotten wet. If it doesn't crank with the key and only by jumping the starter then a safety switch is probably keeping it from starting. It is also possible that one may have come unplugged.
   / JD 4410 won't start #8
I really don't know what I was thinking. I can start mine too. Brain Freeze /forums/images/graemlins/blush.gif
When you turn the key on, can you hear the fuel solenoid click? It sure sounds like a safety switch out of whack.
Well, stupid me, I bought the skid plates but haven't put them on yet!!!! I will check the safety switches. They could have been pulled out when bushogging I guess.
   / JD 4410 won't start #10
Does it smoke when you are cranking it over?
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
BUYERS PREMIUM & PAYMENT TERMS (A51219)
BUYERS PREMIUM &...
2006 CHEVROLET SILVERADO 1500HD (A50854)
2006 CHEVROLET...
2015 WESTERN STAR 4900 SF (A50854)
2015 WESTERN STAR...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
2017 Nissan Murano SUV (A50324)
2017 Nissan Murano...
