JD 4410 wont start
   / JD 4410 wont start #1
2diamondfarm
West Michigan
TYM 574, Deere 4410, Gehl 353 Mini Ex
My 4410 had been having issues with the battery staying up so I changed it and it started right up perfect them my son says there is smoke coming out by the bake pedals so he turns it off .
I take the panels off and start looking for melted wires or something cant find anything, we to try and start it again, it cranks buy wont fire
I took it over to a mechanic friend to look at and he is stumped .
Any one know where to start is there a in tank fuel pump?
Is there a good manual available for this tractor?
   / JD 4410 wont start #2
I would start by checking the fuses, I have include a link to the operators manual. With just the key in the run position, I would see using a volt meter, if there is power to the fuel solenoid. It is located on the fuel injection pump, I have include a link to JDparts, if you need to see where it is located.
I would look at this post:
http://www.tractorbynet.com/forums/...rating/172378-4410-wiring.html?highlight=4410
for the wiring diagram. I would guess the smoke was electrical in nature, what did you son say it smelled like? If you start to do anything with the electrical parts, first disconnect the negative on the battery.
OMLVU13193_H2
John Deere - Parts Catalog
Go to selectmanuals.com and for $24.95 you can download a set of manuals.
Smelled like plastic I thought it could be a melted wire or we blew a in line fuse.
I had been using the battery charger on it before I changed the battery if that helps.
   / JD 4410 wont start #4
Shoot me your email, I have a PDF of the Deere Tech manual you're welcome to
joe
Thanks for the offer Joe
I bought it last night
   / JD 4410 wont start #6
Where all the fuses good to include the fusible link? First order of business is to get the tractor started, I think in that process you will find out what is burning. Then determine the problem with the battery not charging/not staying charged.
Have you by chance added anything to the electrical system ie lights?
I am assuming you have a volt meter and know how to use it to check voltage, test diodes and test relays. If not the manual should give you some help in how to test diodes and relays.
Manual should have a picture and description of the starting system. Do you have power at the fuel solenoid and the key? If you will post a picture of the starting system, I can help you walk through it.
found the problem fuel solenoid timer module the dealer even had it in stock $37 and good to go
Now on to leaky axle seal on the front....
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 GREAT DANE  TANDEM AXLE 48FT DRY VAN TRAILER W/CRANE (A59575)
2013 GREAT DANE...
Case 1083 20ft Corn Head (A56436)
Case 1083 20ft...
2017 JOHN DEERE 544K-II WHEEL LOADER (A52709)
2017 JOHN DEERE...
2014 Komatsu D51PXI-22 (A55272)
2014 Komatsu...
2120 (A58376)
2120 (A58376)
