jd 4410 e hydro pedal pot reset
/ jd 4410 e hydro pedal pot reset #1
wkg2013
John Deere 4410
My jd 4410 won't go forward or reverse. The pedals are attached to linkage that is attached to a rheostat pot. The fault code chart says the "Error status will reset when both pedal commands return to zero". Does anyone know how to reset the f/r pedal command to zero.
/ jd 4410 e hydro pedal pot reset #2
Seems you were just posting about this... maybe it is one or the other pedal sticking and needs some penetrant or lube to loosen it up. ??
