3-Point Hitch JD 4400 HST tractor bogs down like something is binding
   / JD 4400 HST tractor bogs down like something is binding
kennyd: Thank you for the pics...that makes it alot easier to understand. I have looked all over for a diagram but didn't find anything.
RG1: That's good to know. I would have never known they were interrelated. I feel like this will fix my problem and will stay on top of it in the future with good lube. JP
   / JD 4400 HST tractor bogs down like something is binding #12
JP, John Deere parts is free to register at, you can see everything I posted plus a whole lot more. There is a little tutorial linked in my signature if you need help with it.
www.jdparts.com
   / JD 4400 HST tractor bogs down like something is binding #13
And while you're under the tractor, lubricate the range selector where it goes into the transmission case. The range selector is a long lever and any binding can result in $$$ problems.
This isn't directly related to your problem, but it's good to be proactive in preventing another potential problem.
As others wrote...use Fluid Film...works great!
Kennyd: Thanks, I had registered before but for some reason I was blocked but it works now...great resource.
RoyJackson: You're right...as a matter of fact I got them to adjust that linkage since it was hard to get into high range so it seems all the linkage under there needs the lube job and ongoing attention.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59575)
2018 INTERNATIONAL...
Rooster Weathervane (A55853)
Rooster...
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
2013 MAXX-D BUMPER PULL TRAILER (A58214)
2013 MAXX-D BUMPER...
