3-Point Hitch JD 4400 HST tractor bogs down like something is binding
   / JD 4400 HST tractor bogs down like something is binding
kennyd: Thank you for the pics...that makes it alot easier to understand. I have looked all over for a diagram but didn't find anything.
RG1: That's good to know. I would have never known they were interrelated. I feel like this will fix my problem and will stay on top of it in the future with good lube. JP
   / JD 4400 HST tractor bogs down like something is binding #12
JP, John Deere parts is free to register at, you can see everything I posted plus a whole lot more. There is a little tutorial linked in my signature if you need help with it.
www.jdparts.com
   / JD 4400 HST tractor bogs down like something is binding #13
And while you're under the tractor, lubricate the range selector where it goes into the transmission case. The range selector is a long lever and any binding can result in $$$ problems.
This isn't directly related to your problem, but it's good to be proactive in preventing another potential problem.
As others wrote...use Fluid Film...works great!
Kennyd: Thanks, I had registered before but for some reason I was blocked but it works now...great resource.
RoyJackson: You're right...as a matter of fact I got them to adjust that linkage since it was hard to get into high range so it seems all the linkage under there needs the lube job and ongoing attention.
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
UNUSED PABREAK GCC56-2 PRONG HAY SPEAR (A57193)
UNUSED PABREAK...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56435)
PENDING SELLER...
LANDHONOR BS-12-2500G (2) PRONG HAYSPEAR (A57193)
LANDHONOR...
2019 Bobcat E32i Mini Excavator (A55851)
2019 Bobcat E32i...
