Oil & Fuel jd 4400 4wd 159 hrs
   / jd 4400 4wd 159 hrs #1
warrior1942
yanmar 1700m
Just had to replace front end differntial ring gear and pinion, shop replaced fluid with gear oil. Is this the correct fluid to be used in the in the front differntial?
Thanks
   / jd 4400 4wd 159 hrs #2
Front end axle use low viscosity gear oil
Front Axle Gear Oil Low Viscosity HY-GARDョ (JDM J20D (from manual)
Thanks
Front drive shaft seal went out, leaked out all the transmission fluid.:mad::mad:
2017 Chevrolet Trax LS SUV (A55973)
2017 Chevrolet...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A56857)
2018 Toro Z-Master...
2006 Crimson Spartan Fire 105ft. Quint Ladder Aerial Truck (A55973)
2006 Crimson...
Honda UTV (A56859)
Honda UTV (A56859)
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A56857)
2018 John Deere...
