JD 4320 Hydro Static Transmission Problems
   / JD 4320 Hydro Static Transmission Problems #1
Hay Pirate
Orange County, NY
My JD 4320 makes a loud grinding noise at random times when in C-3 or 4. When the "forward" pedal is to the floor. i have to COMPLETELY stop in order for the grinding to stop.
It only happens when going fast in the highest range, C.
:confused:
   / JD 4320 Hydro Static Transmission Problems #2
I had the same problem a couple of times when traveling down the road. The problem stopped when I figured out that i didn't have the shifter completely in gear. Wiggle the shifter some and it should resolve your problem.
ArkLaTexSam
hm, good point! sometimes I have trouble getting it into C, so I'll make sure its secure.
Also, what is the button, left of the steering column, has a wheel with an arrow going around the wheel and one going forward?
   / JD 4320 Hydro Static Transmission Problems #4
You have a tilt steering wheel...?
   / JD 4320 Hydro Static Transmission Problems #5
I'm quite sure all 4320's have tilt steering as standard -- at least that was the case 8 mos ago when I bought my 4320.
   / JD 4320 Hydro Static Transmission Problems #6
If I understand you correctly, it is the switch for "LoadMatch feature keeps the tractor from stalling under heavy loads". Mine is ON all the time as I don't have a reason to turn it OFF.
I'll snap a photo with my phone for reference. I'm pretty sure you're right. I'll try making sure my shifter is in gear as well.
thanks.
   / JD 4320 Hydro Static Transmission Problems #8
That grinding you're talking about was one heck of a noise. I hope to never here it again.
ArkLaTexSam
2016 CATERPILLAR 289D SKID STEER (A52705)
2016 CATERPILLAR...
35in Excavator Tooth Bucket (A55787)
35in Excavator...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2017 Ford F-150 (A53422)
2017 Ford F-150...
2015 Hyundai Veloster Hatchback (A55758)
2015 Hyundai...
GOLF CART (A55758)
GOLF CART (A55758)
