JD 4320 Hydro Static Transmission Problems
   / JD 4320 Hydro Static Transmission Problems #1
Hay Pirate
Orange County, NY
My JD 4320 makes a loud grinding noise at random times when in C-3 or 4. When the "forward" pedal is to the floor. i have to COMPLETELY stop in order for the grinding to stop.
It only happens when going fast in the highest range, C.
:confused:
   / JD 4320 Hydro Static Transmission Problems #2
I had the same problem a couple of times when traveling down the road. The problem stopped when I figured out that i didn't have the shifter completely in gear. Wiggle the shifter some and it should resolve your problem.
ArkLaTexSam
hm, good point! sometimes I have trouble getting it into C, so I'll make sure its secure.
Also, what is the button, left of the steering column, has a wheel with an arrow going around the wheel and one going forward?
   / JD 4320 Hydro Static Transmission Problems #4
You have a tilt steering wheel...?
   / JD 4320 Hydro Static Transmission Problems #5
I'm quite sure all 4320's have tilt steering as standard -- at least that was the case 8 mos ago when I bought my 4320.
   / JD 4320 Hydro Static Transmission Problems #6
If I understand you correctly, it is the switch for "LoadMatch feature keeps the tractor from stalling under heavy loads". Mine is ON all the time as I don't have a reason to turn it OFF.
I'll snap a photo with my phone for reference. I'm pretty sure you're right. I'll try making sure my shifter is in gear as well.
thanks.
   / JD 4320 Hydro Static Transmission Problems #8
That grinding you're talking about was one heck of a noise. I hope to never here it again.
ArkLaTexSam
John Deere 4 Row Corn Head (A50775)
John Deere 4 Row...
Club Car Electric Cart (A55758)
Club Car Electric...
(10) 2" X 6" X 24" TUBING (A54756)
(10) 2" X 6" X 24"...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
2018 JOHN DEERE 410L BACKHOE (A52705)
2018 JOHN DEERE...
2008 CHEVROLET C7500 SERVICE TRUCK (A51406)
2008 CHEVROLET...
