JD 4310 will start but won't keep running
   / JD 4310 will start but won't keep running #1
britanniacreek
Nova Scotia
John Deere 4310
Our 4310, which worked perfectly yesterday started this morning but won't keep running. Starts every time, but then only runs for about 30 seconds and dies....any ideas?? We are NOT mechanically inclined, so can't check much ourselves...
   / JD 4310 will start but won't keep running #2
Sounds like fuel filters. When were they changed last. Also check your air filter box. Mice can build nests in there restricting air flow.
   / JD 4310 will start but won't keep running #3
I'm guessing fuel too...but it could be a safety switch going bad (although that should prevent the tractor from cranking).
Since britanniacreek admits he isn't mechanically inclined, I have to suggest the tractor goes to a dealer...poor troubleshooting can result in a simple problem made worse...
   / JD 4310 will start but won't keep running #4
:welcome:
Does your manual explain how to replace the fuel filter? That sounds like the culprit. Fairly easy to do, if the procedure is followed.
If not obvious, either ask here again for what is understandable and what isn't for additional help, or do as suggested and go the dealer route.
   / JD 4310 will start but won't keep running #5
Prob fuel. But are any lights on or flashing? Either on dash or by the switches on the top of right fender?
   / JD 4310 will start but won't keep running #6
If the fuel filter change doesn't do the trick, I had to push compressed air up into the fuel lines because of debri in my fuel tank.
   / JD 4310 will start but won't keep running #7
:welcome:
Yes, the operator's manual does describe the procedure to change the filter as well as draining the water separator.
   / JD 4310 will start but won't keep running #8
Yes Roy, I knew it did too.
2021 UTILITY VS2DX 53FT DRY VAN (A59575)
2021 UTILITY VS2DX...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A56436)
2019 Krause...
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
