JD 4310 Fault code 2 reverse pedal
   / JD 4310 Fault code 2 reverse pedal #1
disco
Bronze Member
Minnesota, Goodhue County
JD 4310 & JD 4020
Need your help!!!
My 4310 has alot of hours. Getting close to 5000 hrs. Never had this problem. Of course happens when a hay customer drives 120 miles to get to my place. Tractor was running fine. Moved 20 round bales out of the barn to load. Shut off tractor to talk to driver about how he wanted them loaded. Started right up and wont move an inch. Flashing 2 shorts and 2 long lights. All wires are good. Nothing blocking return of pedals. Disconnected battery. Checked all fuses. What I have learned in my research is that it is Reverse Pedal Potentiometer. Code 2. Thinking might be wore out. Should I try to recalibrate? Everything I have read says cant recalibrate if code is flashing.
Thanks Paul
Thanks for the replies. Today unhooked wire harness from each pedal hoping flashing light would turn off. No go. Gonna stop by deere tomorrow.
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56438)
2023 Kubota...
Steel Tire Rack (A57454)
Steel Tire Rack...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
New/Unused SD Lanch SDLE20 Mini Excavator (A57453)
New/Unused SD...
New/Unused Quick Attach Pallet Forks (A57454)
New/Unused Quick...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
