JD 4300 won't crank
   / JD 4300 won't crank #1
wallfarmer
I got JD 4300 a month ago and have had no problems at all until this morning. Went to start it and get nothing but a loud click at back right of engine. Figured it was a safety switch somewhere so unplugged seat switch and then got nothing when key turned. Plugged back in and loud click came back but won't crank. Problem? Thanks for any help you may give.
No, it is not the starter clicking, it is higher up and on right side.
   / JD 4300 won't crank #4
I bet it's the battery...Do the headlights work? Try taking some voltage measurements across the battery terminals-both with the key off and while trying to start.
You need a good battery to fire the intake heater and crank the engine.
Headlights burn bright, but put booster cables on just to make sure and still the same result. Loud click(not starter) and nothing else. Checked all fuses and pulled relays and reseated. Still nothing.
   / JD 4300 won't crank #6
Does loud click occur when key turned to 'run' or when just turned to 'start (crank)' ?
PTO lever get bumped ?
Clicks when turn to run and then nothing when turn to start. Moved every lever on then off hoping something hanging.
   / JD 4300 won't crank #8
Just had same problem with Honda 6522. Fuel pump worked, lights worked. Checked all the safety switches, in neutral etc. Had 12.5v at terminals. Turned out to be a dirty connection on the positive terminal of the battery.
   / JD 4300 won't crank #9
Make sure you have 12v at the starter, could be bad battery cable. The off gassing from the battery eats everything on the 4x00 and 4x10.
   / JD 4300 won't crank #10
Fuel pump selenoid shut-off click? Got 12v there?
AKfish
2014 KALMAR 4X2 YARD DOG (A50854)
2014 KALMAR 4X2...
2018 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2018 VOLVO VNL...
1267 (A50490)
1267 (A50490)
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
BUSH HOG 32601 - 6' ROTARY MOWER (A51243)
BUSH HOG 32601 -...
Unused Delta Crash...
