JD 4300 tranmission problem
/ JD 4300 tranmission problem #1
double hunter
Ford 1715
Looking at a 4300 that is for sale in my area, it has a transmission problem, it will not go forward at all, reverse works fine in all gears and all ranges, tractor looks and runs good , 4wd and loader, , he is wanting 6200 for it, don't know if this a good deal or not, any thoughts on this appreciated
/ JD 4300 tranmission problem #2
Is it a Power Reverser tranny? I assume so because you said "gears". If so it could go either way...from a simple linkage adjustment to a major problem requiring it to be split and rebuilt.
/ JD 4300 tranmission problem #3
It's a good deal unless you have to spend thousands to repair it. Maybe you could get a JD dealership inspection to determine what's wrong and repair cost?
/ JD 4300 tranmission problem #4
Need more info... Year, hours, what does the owner say on how it failed?
2002, less than a 1,000 hrs, the mans brother had it in a small landscape business, probably using operators than were not accustomed to running a tractor, he did tell me that he picked all 4 tires off the ground and they would turn in forward,( for what that's worth)
/ JD 4300 tranmission problem #6
If it's a reverser transmission, first thing I'd look at is the linkage. You'll need to pull the key panel and left side cowl.
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2017 Jeep Patriot 4x4 SUV (A61574)
2017 Jeep Patriot...
2020 GMC AT4 CREW CAB TRUCK (A64280)
2020 GMC AT4 CREW...
2023 Ram 1500 Crew Cab Pickup Truck (A61573)
2023 Ram 1500 Crew...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
BUSH HOG 2720 BATWING ROTARY MOWER (A64280)
BUSH HOG 2720...
