JD 4300: opening up the gearbox to repair broken PTO and range shift
   / JD 4300: opening up the gearbox to repair broken PTO and range shift #31
I very much appreciate your help! Apologies in advance for not getting all the terminology of the parts correct, I realize it makes it harder for folks to understand my questions. For me, a picture really is worth a thousand words.... I think there are snap rings (20) on the end of the forks that hold them to the support body (16)? If that is correct, I am trying to determine if they are accessible from the top of the rockshaft opening so that I can get another fork in there and the snap ring on the end of it?
   / JD 4300: opening up the gearbox to repair broken PTO and range shift #32
I decided not to split the tractor to fix the range shift selector fork. I'm going to button it back it back up and just run it.
My question is, when I removed the PTO cover, there was no gasket. It wasn't leaking, but I want to be sure when I put it back together, that it doesn't leak. I was planning to use
Permatex 82180 Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker​
Can anyone confirm if this the "right" stuff to use? I was also planning to use a light film of it on the suction tube manifold (where the metal screen is located) underneath the tractor as well.
I use RTV silicone like that.
Even if you are too generous with the sealant, dry chunks will just fall into the sump and not cause problems.
   / JD 4300: opening up the gearbox to repair broken PTO and range shift #34
Just a thought with the pto brake issues have you considered installing an over running clutch on your implements.
2012 MACK CHU613 (A50854)
2012 MACK CHU613...
2015 FORD F350 SERVICE TRUCK (A51222)
2015 FORD F350...
2014 Therm Dynamics TD400 Towable Flameless Heater Trailer (A49461)
2014 Therm...
EVERYTHING SOLD AS-IS WHERE IS!! (A50774)
EVERYTHING SOLD...
(INOP) CASE IH MAGNUM 180 TRACTOR (A50459)
(INOP) CASE IH...
CAT D4D (A50854)
CAT D4D (A50854)
