JD 4300 Lift Link BREAKING!
   / JD 4300 Lift Link BREAKING! #1
jorswift
Upland, IN
JD955, MF1528, JD2240, JD 4300, Ford Jubilee
I have a used 4300. The rear says it should be able to pick up about 2,200 lbs.? Well this is twice now the left lift linkage has broken on me. I had it welded once and now it broke in another spot. Both times in the threads. I was only picking up my disc at this time. Anyone have problems with this too? Seems to be a costly repair at $255 per break!
   / JD 4300 Lift Link BREAKING! #2
What is the weight of your disc?
Spec for Three Point Hitch lift capacity is at the Lower Link bullseyes.
Tandem Disc Harrows are cantilevered far to the rear to the Lower Link bullseyes, making disc effective weight much higher than scale weight when pans are not contacting the ground.
Then, when the disc bounces, transient forces increase weight on the Lower Links further.
I'm not sure the weight. It is an older 8' tandem Massey. I know its probably too big for the tractor, but my old Ford Jubilee 9N handled it decently. So figured this tractor would be piece of cake!
The first time it broke, I was carrying a small load of wood on a carry all. Again, I don't believe it to be anywhere the lifting capacity.
   / JD 4300 Lift Link BREAKING! #4
That is very unusual. Those lift links should be able to handle way more than the capacity of the 3PH. I see there was a revision to the design of the 4300 3PH. What P/N did you order as a replacement?
Do you have the sway adjusters tightened up to minimize the side-to-side movement?
   / JD 4300 Lift Link BREAKING! #5
Check if your lowerlinkarm(under the tractor) is inline of your stabilizer brackets hole ?
   / JD 4300 Lift Link BREAKING! #6
This is a discussion that I would be very interested to see pics!
Tractor, disc, 3ph and close ups of the lift arms, links and lower arms.
You know the saying.....a picture is worth a thousand words.
Yes, I had the sway adjusters tightened, but it is hard to get the pin in at times. But I try to get it in the next/closest available hole.
I haven't ordered the replacement part yet. But looking on the diagram, it is part # LVA14235, which replaces my older part.
   / JD 4300 Lift Link BREAKING! #9
Yes - what most tractor 3-point specs explain quite poorly is - the listed weight that the 3-point is rated at, is at the lower link attachment point(bullseye). Some may even list the rated lift out 24 inches outboard of the bullseye. This is all well and good. But here comes the confusion - on any large 3-point implement (Ex - rear blade, rotary mower, LPGS etc) where is the "center of mass" for that implement. The center of mass is the point where we are concerned - what is your 3-point rated to lift at that point. Not at the bullseyes and not at the very rear of the implement.
Center of mass for any implement can also be thought to be center of weight - my way of thinking, completely. I know from an engineering point it DOES get a lot more complicated - but not all of us would understand an engineering explanation. H e l l - I barely understand my own explanation here.
Perhaps an example would be easier to understand. My 2009 Kubota M6040 3-point system has the following rating - - at the bullseye, 4200 pounds 24" out from the bullseye, 3310 pounds
and at 48" out from the bullseye, 2500 pounds.
The heaviest implement I own is my Rhino 950 rear blade. Its 1055 pounds and sticks back of bullseye, on the 3-point hitch, 56". It also has the most rearward center of mass of all my 3-point implements.
My thinking says - center of mass is probably pretty close to center of weight of any implement. Not without a lot of screwing around, I found the center of weight for my rear blade. Its 38" back of the 3-point bullseyes. So I must figure if my 3-point is rated to lift my 1055 pound rear blade at a point 38" back of the bullseyes.
Now referring to the chart for the 3-point lift rating - - 38" back of the 3-point bullseye, my system has a lift rating of 2700 pounds. A little over twice the weight of the Rhino rear blade.
As you might have guessed - - there are those times when I have a lot of spare time on my hands.
There are two sets of data that you will probably have to determine for yourself. The center of mass for your implement and a 3-point lift rating graph/chart.
I obtained the 3-point lift rating data directly from Kubota corporate engineering.
I figure the center of mass is pretty close to the center of weight for any implement.
I am not smart enough to figure dynamic loading - movement of the center of mass when the implement is used - etc, etc.
Bottom line - it could well be that the center of mass for your implement is heavier than your 3-point is rated for - at that point.
Remember - your 3-point lift rating at the bullseyes is only good for a load that is centered directly above the bullseyes - not 24" or 36" or 48" back of the bullseyes.
Here are some pics of it after it was fixe the first time. This time it broke off further down in the threads.
20180109_1.jpg20180109_1.jpg20180109_1.jpg20160808_.jpg20180109_170604.jpg20180109_170610.jpg
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
NEW HOLLAND TN75SE TRACTOR (A51247)
NEW HOLLAND TN75SE...
2020 Featherlite Aluminum Stock Trailer (A52384)
2020 Featherlite...
2018 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2018 Allmand...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
