JD 4300 HST hydraulic filter change
   / JD 4300 HST hydraulic filter change #1
wrede
2001 J. Deere 4300
When changing filter, or cleaning screen, does the hydraulic start flowing out, or just what's in the filter?
   / JD 4300 HST hydraulic filter change #2
You lose a small amount, but there's not much fluid higher than the filter to lose. All in the sump. Be gentle with the hard lines--that little filter likes to stay put.
   / JD 4300 HST hydraulic filter change #3
The trick on Kubota's when changing the filter but not the fluid is a shop vac. Get a helper of tape the hose to the fill hole & turn it on. The vacuum in the tank will prevent fluid from escaping. I'm sure it works for other makes as well.
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
(6) HD 12' Pipe Gates (A50515)
(6) HD 12' Pipe...
Wolverine Quick Attach 68" Bucket (A50515)
Wolverine Quick...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
43021 (A51691)
43021 (A51691)
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A52577)
2016 WESTERN STAR...
