JD 4300 HST hydraulic filter change
   / JD 4300 HST hydraulic filter change #1
wrede
2001 J. Deere 4300
When changing filter, or cleaning screen, does the hydraulic start flowing out, or just what's in the filter?
   / JD 4300 HST hydraulic filter change #2
You lose a small amount, but there's not much fluid higher than the filter to lose. All in the sump. Be gentle with the hard lines--that little filter likes to stay put.
   / JD 4300 HST hydraulic filter change #3
The trick on Kubota's when changing the filter but not the fluid is a shop vac. Get a helper of tape the hose to the fill hole & turn it on. The vacuum in the tank will prevent fluid from escaping. I'm sure it works for other makes as well.
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2025 GIYI GY-X380 Trencher Mini Skid Steer Attachment (A50322)
2025 GIYI GY-X380...
2015 Hyundai Sonata Hybrid Sedan (A50324)
2015 Hyundai...
2012 Peterbilt 382 T/A Day Cab Truck Tractor (A50323)
2012 Peterbilt 382...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
Xtreme XR1045 (A50120)
