JD 4300 HST hydraulic filter change
   / JD 4300 HST hydraulic filter change #1
wrede
Bronze Member
2001 J. Deere 4300
When changing filter, or cleaning screen, does the hydraulic start flowing out, or just what's in the filter?
   / JD 4300 HST hydraulic filter change #2
You lose a small amount, but there's not much fluid higher than the filter to lose. All in the sump. Be gentle with the hard lines--that little filter likes to stay put.
   / JD 4300 HST hydraulic filter change #3
The trick on Kubota's when changing the filter but not the fluid is a shop vac. Get a helper of tape the hose to the fill hole & turn it on. The vacuum in the tank will prevent fluid from escaping. I'm sure it works for other makes as well.
6' Skid Steer Skeleton Bucket (A50515)
6' Skid Steer...
Case SC Tractor (AS IS) (A50774)
Case SC Tractor...
John Deere Hsld 2510 H Nh3 Applicator (A50514)
John Deere Hsld...
John Deere Hay Rake (A50515)
John Deere Hay...
2016 Chevrolet Silverado (A50323)
2016 Chevrolet...
Wolverine Quick Attach Power Rake (A50514)
Wolverine Quick...
