JD 4200
/ JD 4200 #1
ccrutchman
Conway SC
John Deere 4200
I have a John Deere 4200 that I loaned to buddy, when he returned it was covered in mud. The tractor ran fine until I washed it. After washing it when I turn the key I can hear the starter clicking but the engine dosnt turn over at all. I tested the battery and its good. Anyone have any advice.
/ JD 4200 #2
How much water did you get around the starter and or the ignition key? You may have water logged them and they need to be dried out.
/ JD 4200 #3
Is that clicking the fuel solenoidd or the starter.
Suggest pullin, greasing and reinstalling all the relays.
Check wire ends/connections for proper contact. Note there is a singe small gauge wire to the starter.
Check the safety switches
And last: throw a tarp over it and put a small electric under it.:confused:
2022 USA Attachments EB1024 24in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
2022 USA...
2021 PETERBILT 367 (A67714)
2021 PETERBILT 367...
2025 Pallet of Miscellaneous Duplex Polyester Webbing Slings (A66734)
2025 Pallet of...
x (A68191)
x (A68191)
DIGGIT 72MM MULCHING HEAD (A65056)
DIGGIT 72MM...
2012 Mercury 25HP Outboard Boat Motor. (A66738)
2012 Mercury 25HP...
