JD user in Limey Land
Before calling in the local JD agent and putting megabucks in his pocket I am trying to unpick this myself. Engine on my otherwise trusty 13 year old JD 4200 HST compact won't crank. Has been doing this off and on for a while and I put it down to the HST Forwards and Reverse pedals not centering. I've cleaned up the battery terminals, put the battery on charge, checked all fuses - including the 60 Amp one - cleaned up the battery to engine block connection and checked for volts to the starter motor/solenoid. All OK. Getting "clunk" when sitting on seat and turning key (fuel solenoid presumably?) but no starter motor springing into life.
I have no circuit diagram only an "Operators Manual" which came with the tractor (second hand) 8 years ago. I would dearly like to get a circuit diagram because that is the only way I can understand and check the start line circuit methodically. Can anyone help me there please?
My next plan is to check the Diode Block and relays . Then what? Put an earth/negative onto the starter solenoid? ring out the wire from the solenoid to the probable destination? to the keyswitch maybe? That's where I need that circuit diagram most.
Thanks for your help in anticipation.
David
David
