JD 420 loader
   / JD 420 loader #1
jpwazz
Does anyone know how much a 420 fel weighs? I've looked at all the paperwork that I have but nothing tells me the weight. JP.
   / JD 420 loader #2
About 600 to 700 lbs including bucket.
   / JD 420 loader #3
Kenny, I'm going to guess more then 600-700 lbs. Even my old 790's bucket (when off) couldn't be shoved around when it was on the ground (off the tractor). I'd say the bucket alone is close to 300# (61" bucket).
With the masts, frame and bucket, I'd go 800-900 lbs.
I think JD755 has almost every manual Deere ever produced...he may have the specs. I couldn't find the weights in the 430 loader manual.
   / JD 420 loader #4
You may be correct Roy...I was just guessing to give him a ballpark figure to use-I am probably a little low.
Curious why you need to know JP?
   / JD 420 loader
I'm using heavier stuff on the 3-point lately and in close quarters the loader gets in the way. I need to make or buy a front counterweight and am trying to get a ballpark idea of how heavy to make it. JP.
   / JD 420 loader #6
Your best bet is to get suitcase weights for your tractor. Even with the heaviest of implements, you probably won't need more then 200-300 lbs (4-6 suitcase weights). Suitcase weights would be the best "fit" and most compact, but you're looking at $300-$400 for the weights and bracket.
Since you're interested in this, read the thread in the JD Owning/Operating forum about "counterfit mexican weights" (words to that effect).
   / JD 420 loader #7
Have you tried just taking the bucket off?
   / JD 420 loader
Yes, removing the bucket gives me two feet or so of additional clearance on the front end, but I lose out on the weight. In years past I've collected lead from some of the local automotive shops in the area to cast into different items, but some of them now can't give away the lead because it considered hazardous. Concrete in a steel tube would probably work as well. JP.
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
2005 Ford F-550 Bucket Truck, VIN # 1FDAF56P45EB88239 (A48836)
2005 Ford F-550...
2020 Peterbilt 389 Tri-Axle Sleeper Cab Truck Tractor (A49461)
2020 Peterbilt 389...
Adams 5 ton Fertilizer Buggy / Wagon (A51039)
Adams 5 ton...
2014 John Deere 8360R MFWD Tractor (A50657)
2014 John Deere...
2006 Ford F-550 4x4 Flatbed Pickup Truck (A50323)
2006 Ford F-550...
