JD 4130 tires Ag rear, turf front
   / JD 4130 tires Ag rear, turf front #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
I've only Kubotas.
I'm looking at a 4130 4wd that has Ag's in the rear and turfs on the front.
Is that ok for the transmission?
   / JD 4130 tires Ag rear, turf front #2
If the ratio is the same it would be, however, looking at sizes of each tire, it would be nearly impossible to truly match up two different types of tires and keep the ratio correct. I don't understand why anyone would mismatch tires like that.
   / JD 4130 tires Ag rear, turf front #3
Something to definitely be concerned about if the ratio's aren't maintained with the circumference of the tires.
Once again the TBN borg comes thru with good info quickly.
Thanks guys.
   / JD 4130 tires Ag rear, turf front #5
Bet he put the turfs in front because the turning ability of R1s and R4s is ****, because when turning the tractor just skids on those bars that become parallel with the turn. I'm thinking about going to turfs in the front on my 1025. It came with R4s. The R3s on my 4010 had MUCH better turning grip.
Think the fronts go a different speed from the rears anyway. This is why you should disengage the 4wd if going very far on pavement. Otherwise, the fronts just slip a little bit due to the mismatch.
Ralph
2006 STERLING L7500 DUMP TRUCK (A51406)
2006 STERLING...
2005 CATERPILLAR 730 OFF ROAD WATER TRUCK (A51406)
2005 CATERPILLAR...
2008 BMW 535xi AWD Sedan (A53424)
2008 BMW 535xi AWD...
2012 INTERNATIONAL LF687 (A53843)
2012 INTERNATIONAL...
2010 UTILITY TRAILER MFG. CO. 53 FOOT FLATBED (A53843)
2010 UTILITY...
23169 (A50324)
23169 (A50324)
