JD 4120 Transmission issues
   / JD 4120 Transmission issues #1
dunhamg
Waterville, IA
LX 279, 4120
Anyone else ever have this happen with their 4X20 tractor with a PowerReverser Transmission? When I am in C range either 3rd or 4th and get over about 1500 rpm's I get a terrible grinding noise from the transmission. Slow down and it goes away. Tractor has about 300 hours on it and a month out of warranty. Just happened Saturday driving over to the neighbors to help him unload a feed bunk with the loader. Happens both in 2wd and 4wd. Waiting for dealership to come out and take a look at it tomorrow.
Thanks,
Grady
   / JD 4120 Transmission issues #2
I am having this same issue on my tractor Have you heard what the cause was mine has 1440 hrs
Thanks in advance
   / JD 4120 Transmission issues #3
:welcome: to TBN
You may want to send a PM to member dunhamg to get some feedback, hopefully here so others will learn what was the cause of the grinding noise he experienced.
:welcome: to TBN
Sorry, apparently when I replied earlier it didn't post.
It was a loose hose clamp on a hydraulic return line and apparently it was sucking some air and the hydraulic pump is what was making the awful racket. The dealer found it and had to replace a few o-rings in the pump, but otherwise it was good to go. Ended up being a $300 bill for the fix.
Grady
   / JD 4120 Transmission issues #5
Grady
Thanks for the update. :thumbsup:
2025 K3325 UNUSED Double Garage Steel Barn (A50860)
2025 K3325 UNUSED...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
Excavator Bucket (A50860)
Excavator Bucket...
1999 Ford F-550 12FT. Flatbed Truck (A48081)
1999 Ford F-550...
Unused 2025 40ft. Texas Pride FT835524KGN 13 Ton T/A Gooseneck Flatbed Trailer (A49346)
Unused 2025 40ft...
Harrow Drag (A50860)
