Jd 4115 won’t start??
   / Jd 4115 won’t start?? #2
Tim, welcome to TBN 📣
We will need a little more info on your problem.
Richard
   / Jd 4115 won’t start?? #3
Won't start,HELP????
Well if I take it off your hands will that help? If you want to see if you can bring it back to life,here's what I usually found when symptoms are same as you described.
Wiggle pin either broke,bent or missing. If bent it can usually be straightened and might last forever. If broke or missing they aren't available from dealer but can be ordered by phone from overseas where they build them but cost as much as rebuilt engine. You can try salvage yards but it's hard to find a tractor that pin isn't broke,bent or missing.
Greenworks 2700psi Portable Pressure Washer (A56857)
Greenworks 2700psi...
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
2006 Hackney T/A Hazmat Truck (A56858)
2006 Hackney T/A...
2023 FORD F-250 (A58214)
2023 FORD F-250...
LOT: Better Built Heavy Duty Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Better Built...
2007 Terex (A55973)
2007 Terex (A55973)
