JD 4110 questions
/ JD 4110 questions #1
Anonymous Poster
Epic Contributor
Hi All,
First of all, what a great site. I have been browsing for a couple of months. It has definitely helped in making my decision a more informed one.
I am purchasing a new tractor and I have narrowed it down to a the JD4110 w/60"mmm,fm blower,FEL.
I have been wavering back and forth between JD4010,4110, and Kubota BX22 and 2200. I think I have a pretty good grasp of all the pros and cons of th 4 CUT's. In making my final dedcision a couple of things came into play that don't have much to do with performance.
1. My neighbors son is a shop manager at the local JD dealer (5 minutes away) versus Kubota 45 mins away.
2. Right now JD has better financing up here (canada).
After spending many, many hours reading the posts on this site I had pretty much determined that the BX2200 was perfect for me. I don't need a backhoe (neighbour has one and works for cheap). My property is 10 acres, hilly and I cut about 4 acres.
After weighing in the above mentioned JD points I am leaning toward the Deere.
Here are my concers/questions that I would appreciate any thoughts on:
1. Is the 4110 too big/heavy to be used to cut the grass( will it leave indents? Our soil is sandy (very good drainage) and we don't have many low swampy spots.
2.Should I get both turf and industrial tires? I will be doing a moderate amount of loader work as well as blowing snow in the winter ( we get a lot). The driveway is about 500 feet long, level grade but can get drifts up to 36" very often.
3. Here is my biggest concern with the deere...and the reason I was leaning toward the Kubota. We have a lot of hills that I will be cutting and the kubota seems to have a much lower centre of gravity. I am not so concerned with the up and down of the hills it is more the cutting accross the face of the hill. The hills are very irregular in shape. We have several areas where the property resembles a bowl.
My John deere guy (neighbor's son) says it won't be a problem but I am just wondering if anybody out there has any thoughts. I would hate to find out that after spending this type of $ that I can't cut many areas of the property.
Any thoughts would be greatly appreciated!!
Thanks,
Chris Hamilton
Shelburne,Ontario, Canada
/ JD 4110 questions #2
Impossible to give a valid opinion about stability on your hills without knowing how steep, how rough or smooth, etc. </font><font color="blue" class="small">( My John deere guy (neighbor's son) says it won't be a problem )</font> If he's seen it (and you trust him), that's probably your best source of information.
/ JD 4110 questions
Thanks for responding so quickly Bird!!
I just measured some of the slopes and most are around 25 degrees w/ some as much as 30 or a little more. The larger slopes I can regrade though so I guess I am more concerned about the 25 degree range.
All the slopes are very smooth as they were graded with a dozer several years ago.
Thanks again!
I can't wait to post some pics of th jobs I have planned!!
PS. I just spoke with the dealer and he is bringing one out to try!! I will let you know .
/ JD 4110 questions
The dealer came by today and brought out the tractor. No problems handling my hills. Tractor didn't have the deck installed or the tires loaded so all is well.
Should take possesion of my new baby later this week!
Very exciting!!
/ JD 4110 questions #6
congrats.very good the dealer brought th tractor out for u to try on your property. that is the best way to get a feel for it. let us know when u get it and of course pictures are a must.
SQUARE FUEL TANP & HAND PUMP (A63291)
SQUARE FUEL TANP &...
Case skid steer wheels and tires (A63689)
Case skid steer...
2006 CHEVROLET 2500 SERVICE TRUCK (A63291)
2006 CHEVROLET...
2018 Nissan Versa Sedan (A61574)
2018 Nissan Versa...
2017 Mack Semi (A64047)
2017 Mack Semi...
2022 EZ-GO ELITE...
