Backhoe JD 410C shifting problem
/ JD 410C shifting problem #1
dmcb
Inverness, Florida
Mit dozer,John Deere 410C, Kubota, New Holland.
Tractor is stuck in forward. Neutral if in forward. Trying to put it in reverse causes the engine to labor.
I have been told its a stuck valve and the tractor needs to be split to resolve the problem.
My problem is finding someone to work on it. JD dealer 35 miles away wants $1000 each way to haul it to their store and an open checkbook after that.
Is there anything I can try myself and could anyone tell me exactly what I am faced with. Sure would appreciate any help.
/ JD 410C shifting problem #2
Have you tried changing the fluid and filter?
Do you have a repair manual and parts manual for it? If you plan to do any work on it yourself, you'll need to start there.
Thank you. I have not changed the filter and fluids. I have an operators manual only.
I could handle the fluid change if that would work but I am a little long in the tooth for major repair. I keep getting different answers as to the real problem and would at least like to know what the problem really is. If it is possible with my limited discription.
/ JD 410C shifting problem #4
I suggest to check shifter linkage to be sure it's attached correctly & is operational. Also check pressures on reverser control valve.
I did check the linkage and it seems to be operating as it should. After this started it did work perfect again for a bit, then failed.
/ JD 410C shifting problem #6
It's possible the gasket in the photo I posted has failed allowing hyd pressure where it shouldn't go.
Jim, I think you hit on something about the shifter linkage. It is very sloppy but I tried adjusting it and reverse was now neutral. More adjusting and its back to reverse is sill forward. But it did change for the better so I am going to explore that more.
/ JD 410C shifting problem #8
Older JD BH's have a history of faulty reverser linkage but I was guessing on your model.
Don't know the exact year but its older. Wonder if any parts are still available?
/ JD 410C shifting problem #10
Due to the number of units produced I'll guess most parts are available. 410C was produced '86-'90
2018 INTERNATIONAL LT DAY CAB TRUCK TRACTOR (A59911)
2018 INTERNATIONAL...
2002 KRAFTSMAN 10 TON GOOSENECK TRAILER (A63291)
2002 KRAFTSMAN 10...
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
2015 Audi A4 Sedan (A61574)
2015 Audi A4 Sedan...
2022 New Holland SP310F Sprayer (A63111)
2022 New Holland...
KMC 4R INVERTER FRAME (A63291)
KMC 4R INVERTER...
