JD 4100 with MMM---what kind of "cotter keys"
   / JD 4100 with MMM---what kind of "cotter keys" #1
acs55812
Duluth, MN
JD 4100 with MMM---what kind of \"cotter keys\"
In one year I must have lost 6 or more pins that hold the mower on---or 3PH arms ect.
I have used the "hairpin" style (one side straight and the other has --bumps-- that wrap particilaly around the pin as you slide the retainer thru the pin) and standard old cotter keys that are split and the ends spread either direction.
Are some of these better at not falling out than others.
Thanks
Dan
   / JD 4100 with MMM---what kind of "cotter keys" #2
Re: JD 4100 with MMM---what kind of \"cotter keys\"
The best, although not the most convenient, is the regular cotter pin. As you say, they require you bend the split ends with a plier, and then bend them back when you want to remove them.
Brush is really rough on most all the others.
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A49461)
2009 Trail King...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
VERMEER RTX450 (A50854)
VERMEER RTX450...
2017 Bomag BW90 AD-5 Vibratory Articulating Tandem Smooth Drum Roller (A50322)
2017 Bomag BW90...
2007 INTERNATIONAL MA025 DAY CAB (A51219)
2007 INTERNATIONAL...
1975 Dodge 600 Grain Truck (A50514)
1975 Dodge 600...
