JD 4100 with MMM---what kind of "cotter keys"
   / JD 4100 with MMM---what kind of "cotter keys" #1
acs55812
Duluth, MN
JD 4100 with MMM---what kind of \"cotter keys\"
In one year I must have lost 6 or more pins that hold the mower on---or 3PH arms ect.
I have used the "hairpin" style (one side straight and the other has --bumps-- that wrap particilaly around the pin as you slide the retainer thru the pin) and standard old cotter keys that are split and the ends spread either direction.
Are some of these better at not falling out than others.
Thanks
Dan
   / JD 4100 with MMM---what kind of "cotter keys" #2
Re: JD 4100 with MMM---what kind of \"cotter keys\"
The best, although not the most convenient, is the regular cotter pin. As you say, they require you bend the split ends with a plier, and then bend them back when you want to remove them.
Brush is really rough on most all the others.
CRESCENT  MANIFOLD TRAILER (A50854)
CRESCENT MANIFOLD...
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A51039)
Morooka MST 660VD...
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
19009 (A48082)
19009 (A48082)
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A51039)
NEW 2022 Load...
