George Atkins
- Joined
- Nov 14, 2010
- Messages
- 1
I know I am a little late to the party on this, but I was reading this thread when I was having a charging problem with a customer's 4100. None of the responses helped me any but after I finally found the problem I thought I would post it here so that maybe it would help someone.
I had the 4100 in my shop a week prior to it doing what this 4100 is doing.
Customer said it was not keeping the battery charged. We tested the alternator and it was in fact bad. We replaced it, tested the system and tested 14.7 volts. A week later the customer brought it back with the same complaint.
I tested the system everything check OK. Called the customer, he came in I went to show him it was OK and this time it tested 12.2 volts. I checked my test leads and suddenly it was @ 14.2 for a few seconds hen back to 12.3.
This time it would put the charging light out.
I had my service tech check the complete system, he found the regulator was getting hot. We had one in stock so we replaced it. That one also got hot. We then started looking for a short. We by-passed all the wiring from the alternator to the regulator, same thing 14.6 for a few seconds the 12.2
for several minutes. I hooked a volt meter to the battery, turned the switch on, I noticed it would have a heavy currant draw then would unload slightly.
We have not had that much experience with the 4100 and did not realize that it had auto glow plugs like Kubota uses. I disconnected the glow plugs and the system was working fine. Turned out to be the glow plug relay behind the grille. Regulator runs cool, 14.8 charging.:thumbsup:
