JD 4100 Compact Utility Tractor 4WD issue with front spindle
   / JD 4100 Compact Utility Tractor 4WD issue with front spindle #1
Clear Creek Kennel
4100 John Deere Utility Tractor and 332 John Deere Garden tractor
I have a JD 4100 Compact Utility tractor and when backing a 4 wheel wagon in I had the 4wd engaged and turned very hard to the right while in reverse. I noticed a popping noise, in right front housing sounded like the knock in a bad universal joint. I immediately pulled it in the garage first shifting it out of 4WD. About every 1/2 rotation the hub would pop and the wheel was wobbling side to side moving 1/2" each way during rotation. I just wondered what i am into and if anyone has experienced this situation.
   / JD 4100 Compact Utility Tractor 4WD issue with front spindle #2
Welcome to TBN
Sounds like time to check into it further.
If interested in taking on such a project, get the service tech manual for some help doing it yourself.
Do some searching here on TBN for other similar projects/problems/solutions/fixes.
Explore the parts site and should get some good ideas what makes the front end function.
   / JD 4100 Compact Utility Tractor 4WD issue with front spindle #3
Check your private messages
2011 COMPTANK ACID TRANSPORT TRAILER (A55745)
2011 COMPTANK ACID...
20" Sea Container (A47384)
20" Sea Container...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56138)
2020 FREIGHTLINER...
2007 Ford F-150 Ext Cab Pick-up Truck (A53422)
2007 Ford F-150...
New Three Point Hitch Trailer Mover (A54865)
New Three Point...
2018 John Deere 470G LC Hydraulic Excavator (A53421)
2018 John Deere...
