JD 4100 Compact Utility Tractor 4WD issue with front spindle
   / JD 4100 Compact Utility Tractor 4WD issue with front spindle #1
Clear Creek Kennel
4100 John Deere Utility Tractor and 332 John Deere Garden tractor
I have a JD 4100 Compact Utility tractor and when backing a 4 wheel wagon in I had the 4wd engaged and turned very hard to the right while in reverse. I noticed a popping noise, in right front housing sounded like the knock in a bad universal joint. I immediately pulled it in the garage first shifting it out of 4WD. About every 1/2 rotation the hub would pop and the wheel was wobbling side to side moving 1/2" each way during rotation. I just wondered what i am into and if anyone has experienced this situation.
   / JD 4100 Compact Utility Tractor 4WD issue with front spindle #2
Welcome to TBN
Sounds like time to check into it further.
If interested in taking on such a project, get the service tech manual for some help doing it yourself.
Do some searching here on TBN for other similar projects/problems/solutions/fixes.
Explore the parts site and should get some good ideas what makes the front end function.
   / JD 4100 Compact Utility Tractor 4WD issue with front spindle #3
Check your private messages
2012 Case IH Patriot 3330 Self Propelled Sprayer (A50657)
2012 Case IH...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
2013 Nissan Sentra Passenger Car, VIN # 3N1AB7AP8DL772101 (A50324)
2013 Nissan Sentra...
SCAN FOR HAULING AND FINANCING INFORMATION (A51242)
SCAN FOR HAULING...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A50854)
2013 XLR...
2014 Dodge 5500 4X4 Bucket Truck (A51039)
2014 Dodge 5500...
