JD 4100 battery light
   / JD 4100 battery light #11
You can engage the rear PTO while off-the-seat by lifting the seat and then pulling the seat switch UP-at least that's the way my 4110 is...
   / JD 4100 battery light #12
Try to perform the test completely so we can better determine your problems.
steve
Well, I was able to engage the rear PTO at idle and was getting 13.6 volts, then I shut off the PTO and was still getting 13.6 volts.
   / JD 4100 battery light #14
Was that a fast idle? If it was that seems low to me. On your tractor is this a belt drive alternator? May want to check the belt tension. If you raise the engine speed to a fast idle it should rise above 14.0 volts when battery is fully charged.
13.6 volts will allow for a slow charge to your battery, if you can add the pto and lights at a fast idle and still maintain this you might be okay. I doubt from your measurements that the pto clutch is the problem and you should be able to mow with it without harm. I would think your alternator is not keeping up but a bad battery can drag down the voltage too. I think it would be wise to take the battery in and have it load tested to help eliminate it as a source of the problem. If the battery checks out good and is replaced fully charged then you should get readings near 14.0 volts when running. If not then I would remove the alternator and have it tested and or repaired.
Steve
2025 JMR 40in Single Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 40in...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2016 FREIGHTLINER...
2001 International 4700 Bucket Truck, VIN # 1HTSCABNX1H380565 (A54865)
2001 International...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
2008 JLG 800S TELESCOPIC MANLIFT (A52705)
2008 JLG 800S...
