JD 4020 series hydraulics?
   / JD 4020 series hydraulics? #1
mechatgsk
Wilson, NC
Kubota M7060
Hello, I was wanting to view how the new EH 3rd scv, the 4th & 5th scv, and the Power Beyond kit plumb together on the new MY2011 4020 series compact tractors (Open Station). I have looked at JDParts with no luck viewing the whloe system plumbed together.
Regards,
Mechatgsk
   / JD 4020 series hydraulics? #2
Not sure I fully understand the question? What exactly do you want to know? This is a entirely new setup from JD so info is somewhat limited.
   / JD 4020 series hydraulics? #3
Regards,
Mechatgsk
Best I can do is a cabbed install photo. Sorry no Power beyond.
   / JD 4020 series hydraulics? #4
The switches are at the top/right marked IV and V.
Hope this helps.
Hello, I will try and explain the question better. I would like to see a drawing or actual photo of the new 3rd EH scv kit, 4th & 5th scv kit and Power Beyond kits installed together on a 4020 series open station tractor. Thanks to all previous replies!
Regards,
Mechatgsk
   / JD 4020 series hydraulics? #6
Hello, i was wondering what does "scv" stand for?
Also I was hoping someone can help.
I recently purchased a 1967 4020 with power shift and only 2 hydraulic hookups.
I need 3 (loader with grapple). Also the 2 levers I do have are located on the left side of the dash, which is completely useless for loader work. Local dealer quoted me a price of $5600. To install a joystick and a power beyond kit. This is not an option. Any ideas? Thanks, Robert
   / JD 4020 series hydraulics? #7
Valve Kits for your 3rd valve.
You may want to start a new thread, as the 4020 you are talking about is different than the 4000 TWENTY series the original poster is talking about.
   / JD 4020 series hydraulics? #9
SCV = Selective Control Valve
With a 4020 try posting in the John Deere AG Tractor section
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
2015 MACK GU713 (A50854)
2015 MACK GU713...
2015 VOLVO VNL SINGLE AXLE DAY CAB (A51222)
2015 VOLVO VNL...
2010 John Deere Gator UTV (A49461)
2010 John Deere...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A51039)
2014 Doyle Dry...
2003 John Deere 1790 Planter (A50657)
2003 John Deere...
