JD 4010 Compact won't start after snow plowing
/ JD 4010 Compact won't start after snow plowing
Yeow ! the same thing happened this AM !!! Ran beautiful yesterday and today same thing. Went below freezing last night but in the 40's right now and nothing. Thanks for the tip on block heater. Hope I don't have a bad switch that will act up now and then.
/ JD 4010 Compact won't start after snow plowing #22
Block heaters are nice but a tarp and a a 1500 watt heater will work just as well if not better as the whole tractor gets warmed. It should only take an hour or so.:)
Thanks. Since I don't have a block heater on hand, will use the tarp and hearer again tonight. Thanks to all. Keep you informed
To all who helped me 2 yrs ago. A big thanks !!!! Had same problem this year (no snow last yr). Called JD and they said sounds like seat switch. Unhooked it and then re-hooked up and it ran great. Mia cuppa ! Switch was bent and misshaped because when I run PTO from the ground I stick a screw driver in the button. Been doing it for years. Payed the price. Thanks again. Why are learned lessons so expensive ? Bruky
GIYI SGB20-20" HYD STUMP GRAB BUCKET (A60430)
GIYI SGB20-20" HYD...
Toyota SR1-BET35 3,500 LB Stand-On Electric Forklift (A59228)
Toyota SR1-BET35...
UNUSED RAYTREE RMDB82-DIGGER HYD BACKHOE (A60432)
UNUSED RAYTREE...
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
404 (A52706)
404 (A52706)
